Raven pre-shipping (Weapon) audio I/O question
Craig Meadows
Pensacola, FL
vimeo.com
The current shipping Weapon Base I/O expander and the future V-lock version packaged with the Raven have 3.5mm mic input and headphone output jacks.
I often need to record in camera and not sure I have the budget for the higher end expander with XLR inputs for external mics. I've read the Weapon operations manual and internally the Weapon seems to have o.k. preamps and 48kHz quality.
For those of you currently using the base I/O expander what is your experience recording external audio directly to camera? Do you have enough signal strength for both the mic input and the headphone out and is it just o.k or quite usable?
I have a A-Box XLR adapter that would give me XLR inputs. With my 1DC I'm running a S-Devices Mix-Pre D that has worked out very well, but prefer to keep my rigs as compact as possible.
Thank you.
P.S. Not sure how many Weapon systems may be out there in the wild so I know this may be a bit premature question.
The A-Box converts 3p XLR balanced to 3 conductor TRS balanced x2. Epic/Scarlet have two mic inputs. The Base Expander has only a single 3 conductor TRS jack for a pair of unbalanced audio channels.
Dave, will a 3.5" splitter like this work to use two mics in?
I don't think that will work Elsie, I might be wrong but you need the 3.5 going into the camera to be dual mono, so one mic goes to one channel and the other to the other channel, otherwise you're just muxing down both mics to stereo input. No chance of splitting in post, however something like this should do the trick http://www.gear4music.com/Books-DVD...=24287460854&gclid=COqk9-HGrcgCFQFQ2wodz8cCEw
Thanks Alex. I think I have one of those on hand... I'll try it when camera arrives.
Will the current Pro I/O module fit on the back of the Raven?
Stephen
So now we can plug in something like the Rode Stereo Videomic Pro with no issues?
I can't find the specs for the v-lock expander. Will it have an HD-SDI output?
