Rattling V-lock Batteries
Liam Murphy
Active member
UK
Hi,
Does anyone else's third party batteries rattle around on the backplate? Any fixes other that duct tape?
I understand that I'll never get a perfect fit but its going to drive me insane!
Its a Red Scarlet X - Camtree Hunt Quickback - Hypercore 98
Cheers!
its most likely the cam tree quick back, almost everything they do is slightly imperfect.
Thanks Jordan!
What if I upgrade slightly to the Wooden Camera quick back with Hypercore 98?
Anyone have this set up?
Thanks Jordan!
I use the Wooden Camera Blueshape version and it's the tightest v-mount plate I've ever used. Strong materials for sure and I highly recommend it. First week or so of shooting you are going to want to make sure it's locked down all the way. It's a bit stiff at the beginning but then finds itself in a solid place shortly after.
Awesome! Thanks for the advice, I'll check out the RRP on one now...
If it's not too late, I would consider switching to a Gold Mount battery and battery plate solution. It'll be slightly more expensive than a comprobable V-Mount setup, but the Gold Mount is mechanically much stronger. You won't ever run into a rattling situation unless your battery plate isn't properly connected to the camera.
Thanks for the advice Marcus! But I've just purchased a second Hypercore, so I guess i'll be changing the plate to try and resolve the rattling
