R3D to Pro Res metadata
David Ellison
Manchester UK
I've turned a load of R3D's into pro res files through premiere but so far I cannot see the exif data in the new pro res files, does that not
transfer across?
The settings are right in premiere to transfer across all meta data but when I check the pro res files in the premiere metadata window
all the info is blank.
