Antoine Baumann
with this one you can change pan&tilt position with a joystick:
http://brushlessgimbals.com/p/872288...ack-magic.html
Because of their incredible versatility, I predict these MōVI competitor, low-cost gimbals will definitely replace steadicam w/pro op. on every ultra-low and micro budget production.
Very interesting thread, Terry.
I don´t think at all that those new gimbals have anything to do with a steadicam. It´s a new tool.
In my opinion a steadicam is not only a camera stabilizer, it is "full body driven eye". Every slight change of position, moving the hips, leaning forward or backward...every movement of the body translates to the camera. And this is the art of steadicam, it is like a painters brush on the canvas. This immediate ability to react to the smallest impression makes every operator unique. A good operator is more like a DP for the unpredictable slight changes in movements and arrangements. And this have nothing to do with a 2 men crew. Just have a look at the work of great operators, like Larry Macconkey "Good Felllas"..or Jörg Widmer in "Tree of life". The whole choreography is designed by them. Jörg Widmers work in "Tree of Life" is just full of understanding what´s going on around him and he reacts with the camera like a poet would do with words. Garrett Brown loved the hand camera of the nouvelle vague, but he wanted to have it more stable and smooth. Then he invented the steadicam. And the side effect of the steadicam is the stabilizing of the shot, but its not the "heart"of the steadicam. He wanted to move the camera, not only to stabilize it. The first long shot in "Bound for glory" was not only a great shot because it was stabilized. It was the more then that, like a " spirit of the movement" down from the crane into the scene. All the excitement and compassion for what´s before and around Garrett Brown is in it. Now imagine the same shot with a supertechno. It is another world, would be another movie.
One of the very big advantages of the digital filming is that the capture part can be isolated from the rest of the camera. I think because of this we will soon see a kind of stabilizing the picture (in the Movi/ Gimbal way) by the separation of the sensor/lens part from the rest of the camera. BTW you find this technic already in smaller Sony cams. Until then I think this newly developed gimbals will serve well, but not to replace the steadicam.
Maybe one day the steadicam will be obsolete, I don´t know, but until then I´m a bit afraid this new gimbals will flood us with long and meaningless shots with amazing movements...but hey, that´s fashion and the show must go on.
Marc
What I'm saying is they both produce a stabilized image. The exact same shots can be accomplished.
Obviously they aren't technically the same thing. But on screen it makes no difference.
Very much agree...
We questioned our Steadicam purchase for some time after MoVI announcement & while initially thought easyrig would be the way to go, have since settled on mounting gimbal to steadicam not only for stability but to give the op some support for long shoots.
we should have some tests done soon & are curious to see if others are mounting gimbal directly to arm, or attaching to sled / post assembly & how each method affects resulting shots.
PCG
Hey thinking about it... Why doesn't someone make a roll axis only stabiliser to interface with a normal steadicam that can then take larger cameras? Wouldn't this be MUCH easier to do these days with all this gimbal stuff flying around? Wouldn't that be the best of both worlds? Just an active rocker plate of some sort.
I hope this will be my last post on this subject.
What I'm trying to explain to you is that a gimbal is not dampened for Y or X movement. It only controls the interest point of the camera So a gimbal carried around by an operator is not smother in position than any other carried camera, read hand held, shoulder rig or you name it. A steady cam differ in that regard, due to the fact that it's held by a dampening arm that if working properly pretty much mute all Y shakes... If you think a movi operator can learn some special skills to dampening his cameras position in space better than without the rig, well then you think wrong. As (again) all the gimbal does is stabilizing the interest point of the camera it does not help the camera position to be stable. On the conterary the rig itself probably make things worse as it's quite heavy to hold etc.
So interest point and position is two completely different things.
And also learn that paralax change is only, and by nothing else, depending on camera position. What lens is used has nothing to do with it what so ever and will never have.
The problem even there is the immediacy of a Steadicam op is lost. As beautiful Steadicam shot is not just smooth, it combines quick pans and tilts with smoothness and in this way very much replicates what it feels like to walk through a real space. Getting that same "humanity" using joysticks controlled by a second person who does not know what your next move will be, exactly, or the very robo-ish "majestic mode" - good luck.
WHat I see is two camps from this:
1 - Very low end directors/producers with little to no education in film think all they need is a Movi. Since these people have little training or specialized knowledge themselves, they tend to undervalue other people's specialized knowledge and abilities (wether they be Steadicam Ops or DPs) and assume it can easily be replaced by some gadget. This makes psychological sense, because whereas it would take them a long time to develop knowledge and expertise, if all you need to be a good filmmaker or member of a team is to buy the right gadgets then they stand a chance, in their minds, of being valued members of the production community after purchase of such gadgets. I call that "hiding behind your gear". We've all been guilty of it on occasion, but the less talent or knowledge you deep down know you have, the more you need that crutch at all times.
2 - Higher end directors with experience, training, education and some culture/refinement see it as a specialized tool that opens up new possibilities but does not replace nor better dollies, Steadicam and cranes in any way, except in very particular situations.
Have a glance at who is posting which claims about Movi (or any new "game changing" tech) - you'll see that the world is divided rather neatly into "1" and "2".
If you look back historically, the ability of the human to predict the future is worse than pathetic. It's so bad I struggle to find a fitting descriptor. When I come across people trying to be prescient, it usually comes from a touch of arrogance. Fact is, nobody knows how this technology will ultimately matter. NOBODY!
To clarify some issues which have been raised in this thread: the motion of a rigid body in three dimensional (Euclidean) space involves 6 degrees of freedom. One may express the degrees of freedom as three translations plus three rotations. The gimbals are meant to compensate undesired rotations while a steady cam compensates for the translations (that is displacements) especially in the vertical direction.
If one is shooting very close to the ground level, such as the steady cam operators in football/soccer matches, rather small translations especially in the vertical direction tend to create big changes in the camera view, and this is why compensation of the vertical translations is critical. In the same manner if one shot something located very close to the lens, then elimination of the horizontal displacements became also important. In case of aerials, the small changes in height have a smaller effect compared to small changes in rotations, and consequently, compensation of rotations become the main emphasis. So there is a clear need for both steady cams and three axis gimbals.
A system that compensated for all six degrees of freedom is an interesting thought, although not that trivial to implement. Especially so motion is always relative to something else. This meant the user should be able to communicate the desired motion to the system to prevent the system from compensating for the desired translations and rotations.
