Progress Report from NAB on LED Fresnels
I have been following the development of LED Fresnels with interest and so couldn’t wait to see what would be introduced at NAB this last weekend. I am happy to report that definite steps have been made in developing a production LED Fresnel light that combines the advantages of LED illumination (cool-burning, energy-efficient) with the versatility and control of traditional Fresnel fixtures. To reach this point, manufacturers of LED fixturess had to overcome a number of problems. The biggest problem of LED lights in the past was their poor color rendering (use this link - http://www.oscars.org/science-technology/council/projects/ssl/index.html - to the Academy of Motion Picture Arts & Sciences’ “Solid State Lighting Project” for details.) In addition to having poor CRIs, LED output and color decays with age, making their color rendering capability inconsistent at best.
A second problem inherent in LEDs that manufacturers have had to address is the relatively poor power quality generated by the Switch Mode Power Supplies (SMPSs) they use to power their lights on AC power. With Leading Power Factors around 0.54 (Litepanel 1x1s) and high harmonic distortion (THD upwards of 68.1%) the AC power supplies of LEDs have generally drawn a very distorted current that is significantly phase-shifted with respect to the sinusoidal voltage waveform. As such, the AC power supplies of LEDs have had an adverse effect on power quality similar to that of CFLs (use this link for more details.)
Finally, another drawback to LED fixtures until now is that the "light panel" design creates a light that is hard to control and falls off very rapidly. These characteristics have made LED light panels only suitable as Key sources in documentary interview set-ups where the Keys are typically positioned close to the interview subject. In that capacity LED light panels (with heavy diffusion) can generate a wonderful soft light that wraps around the interview subject without wilting them. However, in dramatic set lighting, where Key sources must be capable of throwing a distance, LED light panels have only limited applications as fill sources. The broad soft light they put out drops off too rapidly, and is too difficult to control, for them to be effective as a Key or Backlight source in dramatic set lighting. For LEDs to be widely used, manufacturers had overcome these shortcomings - their poor color rendering, poor power quality, and lack of versatility - to previous LED light designs. As I said at the outset, progress has been made on many of these fronts in the fixtures being introduced at NAB this year. Particularly in the case of the Litepanel Sola 6 Fresnel and the Arri L7 Fresnel.
The Litepanels Sola 6 LED Fresnel​
While the Sola 6 Fresnel is definitely a step in the right direction in developing a production LED, far as I am concerned, Litepanels has not completely overcome all of the shortcomings outlined above with the Sola fixtures. Litepanels doesn’t give CRI ratings for the Sola Fresnels on their website, but when asked they say the CRI is in the 80s – which is still rather anemic compared to continuous spectrum light sources like quartz and HMI lights. The Power Factor of the Sola has been improved. But, at .85 it could stand further improvement (a Power Factor Corrected HMI has a Power Factor of .98 or near unity power.) They claim the 75W Sola 6 has the output equivalent to a 650W Tungsten, but comparing the photo-metrics published on their website to those of an Arri 650 Fresnel, the Arri has nearly three times the output of the Sola. And, while the Sola 6 has an impressive spot to flood range (10 to 70 degrees), spot/flood capability is not the only characteristic that makes a Fresnel light versatile. Of equal importance is the ability to render clearly defined shadows and cuts. The ability of Fresnels to render crisp shadows make them ideal for creating gobo effects like window or branch-a-loris patterns. The ability of Fresnels to render clearly defined cuts enables their light to be precisely cut to set pieces and talent. And, simply by adding one of a variety of diffusion material you can vary the softness of a Fresnel’s output. These are the characteristics of traditional Fresnels that make them extremely versatile, that the Sola “Fresnels” have not been able to emulate. Arri, on the other hand, may have finally engineered in their new 200W L7 LED Fresnel a fixture that combines the cool-burning, energy-efficient advantages of LED illumination with the controllable versatility of traditional Fresnel fixtures. Where I am out of space, I will have to pick up with my review of the new Arri L7 LEDs Fresnels in my nest post.
Guy Holt, Gaffer, ScreenLight & Grip, Lighting and Grip Rental and Sales in Boston.
  • Thread starter
  • Banned
  • #2
As you can see in the pictures above, that compare the output of the L7 Fresnel to an Arri ST-1 Quartz Fresnel, the L7 Fresnel has clear and defined shadow rendering capability like that of the ST-1 Quartz Fresnel. And, as the pictures below demonstrate, the L7 Fresnel has a spot to flood range similar to that of the ST-1 Quartz Fresnel and excellent field homogeneity in both flood and spot.
And, just like the ST-1 Quartz Fresnel (pictured below), the beam of the L7 Fresnel (pictured above) is easily controlled with barndoors - enabling the light to be precisely cut to set pieces and talent (see far right photos above & below.) And, given the discernable amount of light the L-Series Fresnel prototypes threw in a show demonstration video from IBEC last fall, on what appears to be a 6x6 Ultrabounce rigged 20’ overhead, and under the high ambient light levels of the show hall, it seems the production model L7 Fresnel has more than enough output to waste some to diffusion and color gel if one so desires (a shortcoming to most LED panels is that they have barely enough.)
The L7 line of LED Fresnels introduced at NAB consists of three models: the L7-D, L7-T and L7-C. All share the same basic housing and the same 7" Fresnel lens, and all have output comparable in intensity to a conventional 1K Fresnel. They differ in terms of color temperature, with the D model outputting a daylight-equivalent 5600 K, the T model a tungsten-equivalent 3200 K, and the top-of-the-range C model offering total color control. In my opinion, the Arri L7s finally deliver the true-to-life color rendition, previously achievable only with full-spectrum tungsten sources. By color blending with a multi-emitter LED engine, the L7 is able to overcome the generally poor color rendering capabilities of other LED fixtures. Both the 3200 K and 5600 K color temperature models offer a CRI and CQS greater than 90 so skin tones, costumes and scenery will finally appear life-like under LED light.
The L7-C’s fully tuneable white light can be adjusted for different skin tones, camera sensors and mixed-light environments, while specific color shades can be matched through full gamut color mixing. Unlike other LED fixtures, this level of color control does not involve compromising the quality of the light field: the L-Series is unique in combining uniform light and single shadow rendition with absolute control of color attributes.
Split Macbeth chart: each color patch shows the visible effects of studio tungsten light in the top half of the patch, and a representative multi-emitter LED lighting instrument in the bottom half. Note: this is not the L7 but results typical of the multi-emitter LED approach ​
An added benefit to using a color blending multi-emitter LED engine is that the L7’s firmware can calibrate the blend of different color emitters to compensate for the inevitable color shift of the LEDs with age. This approach assures consistent realistic color rendition throughout the fixture’s life.
There are two alternative cooling systems: one passive and the other active. The passive cooling system was designed for broadcast studios. It incorporates no moving parts or fans and is therefore completely silent. The active cooling system was designed to provide a more compact and lightweight option for location work. It uses an extremely quiet (<20 dB) fan and weighs 10lbs less than the studio version.
The location fixture carries an IP54 rating for weather resistance which means that it is protected from falling rain and splashing water, and that the internal electronics, optics and LEDs are protected from dust, dirt and humidity – making it a very robust fixture that will stand up to the rigors of location production.
All the L7s feature Power Factor Correction with a near unity Power Factor of .91. Which means that the 200W fixtures will draw no more than 1.98A at 120V (220W) and cause virtually no Harmonic Distortion. Since it creates virtually no line noise, you will be able to power nine 200W L7s on the 20A circuit of a portable generator without a problem. And since the L7-T has an output comparable to a 1k Quartz Fresnel, and the L7-D has an output comparable to a 575W HMI Fresnel, the L7 series takes what you can do with a portable generator to a new level. For example, with the enhanced 7500W output of our modified Honda EU6500is, you will be able to operate a lighting package consisting of a 30 L7s. I think you would have to agree that is an incredible step-up in production capability.
At a price around $2’500, the L7s are one of the more expensive LED fixtures at NAB. But, to assure that they are not quickly rendered obsolete by the rapid advances being made in LED chip efficiency, Arri has designed them to be an expansible platform that can incorporate future developments in LED technology. Not only, do the heads allow for the incorporation of more efficient LED chips when they become available, but the light engine is also fully upgradeable, ensuring that the fixtures can take advantage of technology advances as they happen.
To accommodate future control protocols (such as ANC), their firmware is also upgradeable through the USB port on the rear of each unit.
They will also be compatible with planned future optic accessories that will expand the L-Series versatility. Able to incorporate future developments in LED technology, the expansible platform of the L7s ensures that they will have a long useable life and so will assure a return on investment in them. Given the rapid pace of LED chip development, I can’t think of another LED fixture that won’t be obsolete in a year or two. The scheduled release for the L7 LED units is September 2011.
With the same clear and defined shadow rendering, excellent field homogeneity, and smooth continuous flood to spot focus as a 1kw Quarts Fresnel, these first production models of the L-Series LED Fresnels may well be the first true LED Fresnel lights (use this link for more details.) For more detailed information on the Power Quality generated by LED power supplies and to see a demonstration video of the new Arri L-Series LED Fresnels, use this link to an article I wrote for our company newsletter on the use of portable generators in motion picture lighting. In it I cover some of the basic electrical engineering principles behind LED drivers, the harmonic distortion they can generate, and how it can adversely affect generators. The article and the demonstration video are available online at http://www.screenlightandgrip.com/html/emailnewsletter_generators.html.
Guy Holt, Gaffer, ScreenLight & Grip, Lightng & Grip Rental in Boston
Thanks for the very detailed and thorough report Guy!
Guy, I was very interested in hearing more about these as I am unable to attend NAB this year. All I had seen up to this point were the press releases. This is a very thorough description of where the technology is at, especially with these particular instruments from Arri.
So, when do you want to test them with my RED?
Thanks for sharing this!
Thank you for a great in depth report on the state of LED lighting.
I was doing some paper-only (since I couldn't make it to NAB) research myself, and had a lot of the questions you answered.
Despite the awesome advantages of LED fixtures I think I simply have to hold off on any purchases until they are priced more reasonably. At $2500 per fixture, its hard to justify compared to tungsten.
I was wondering if you had a chance to look into fluorescent fixtures. I am particularly interested in the DivaLite 401 fixture. As far as I can tell its a minor update to the 400, but I was wondering if perhaps the 401 was PFC or had some other "hidden" improvements. I was also wondering your opinion of the various KinoFlo competitors ... especially the Lowell and CoolLights fixtures. I see a number of units competitive with the DivaLite 400, but frankly keep coming back to the DivaLite (and the ParaBeams)
  • Thread starter
  • Banned
  • #7
Up until now I would have agreed with you. I was of the opinion that except for special applications requiring battery operation or for travel kits, LEDs did not offer sufficient additional benefit in general production applications to justify the cost – especially when the technology was evolving so rapidly that anything you purchase would be obsolete in a year or two. But, I do think that Arri did several things right with the L7 that changes the cost/benefit calculation of LEDs.
Knowing that their LED Fresnel line was going to be more costly per lumen than other light sources, Arri realized that there had to be an additional benefit or savings to justify the additional expense for them to be successful in market segments other than Broadcast Studio Installations. The benefit in the broadcast studio market is compelling: when you take into account the savings in power consumption (not only by the lights but also air-conditioning), lamp longevity (no need to replace burnouts), and gel longevity (no need to replace burned through gels), the benefits clearly outweigh the additional cost. On their website, Arri estimates that a studio with 50 1kw instruments will save approximately $148,000 over a five year period by using the L7 LED Fresnel instead.
The “green” benefit is also compelling. Using L7s in place of 1kw Quartz Fresnels would save 450 tons of Co2 emissions and 964 barrels of oil. Or to put it another way, the use of 1kw Quartz Fresnels would require the planting of 10,600 trees to offset the additional carbon footprint. Without a doubt, the saving to be gained in the Broadcast Studio market more than offsets the additional expense of an LED Fresnel fixture.
But since the same cost/benefit analysis isn’t as compelling in location production applications, Arri added several features not necessary for studio applications, that would make the benefits outweigh the additional costs for small production companies and camera owner/operators. One feature that offers tremendous benefit in location production is the fully tuneable color blending multi-emitter LED engine that they offer in the L7-C model. Capable of full spectrum tuneable white light with a CRI and CQS greater than 90, this LED engine makes the L7-C fully compatible with existing Tungsten as well as Daylight Light sources and makes it able to match to mixed-light environments without sacrificing output to color correction gels.
Tuneable white light is a feature that benefits Red users, as well as users of DSLRs, in particular. One downside to lighting for the Red’s native color balance of 5000K in the past has been that it requires an all 5000k balanced lighting package and HMIs are considerably more expensive to buy or rent. Kino Flo fixtures, particularly the Parabeams, were a cost effective alternative to HMIs because they could use either 3200K or 5500K tubes. But, the drawback to fluorescent fixtures has always been that they generally have a very broad soft light output that drops off rapidly which means the units need to be positioned close to the subject they are lighting. This characteristic has always made them better suited to lighting documentary interviews than dramatic scenes. With a 5600K output comparable to that of a 575 HMI Fresnel, the Arri L7-C offers the same benefit of being a less expensive alternative to HMIs, but also the added benefit of being more versatile than a Kino Flo. Not only does it offer the capacity of traditional Tungsten/HMI Fresnels to throw and control its light output (making it a more suitable Key and Backlight source for lighting dramatic scenes), but it also has sufficient output to bounce it or waste some output to diffusion material to make it softer (existing LEDs put out barely enough, with none to waste.) It’s capacity to provide both hard crisp light that will throw a distance and is easily controlled, as well as offer soft light with diffusion, makes the L7-C much more versatile than any Fluorescent or LED light presently available. One L7-C will be able to do what it takes four Litepanel 1x1s to accomplish (spot and flood in 5600K and 3200K color temps) and more.
Another feature that Arri has included in the L7s to benefit location production is Power Factor Correction (PFC.) Without a doubt, the even greater reduction in power consumption, and particularly line noise, that Arri achieves (that other LED manufacturers don’t) by incorporating PFC into their L7 Fresnels offers location productions an even greater cost benefit: not having to rent a movie blimped tow generator, with all of its’ hidden costs, in order to obtain decent production values.
Until recently, to power a lighting package sufficient enough to get good production values required a large diesel tow generator. Movie generators are not only expensive to rent, but they come with hidden costs that usually break the budget of modest HD projects. Movie generators require special tow equipment not found on Ryder or Penske rental trucks. For that reason, movie generators require that you rent a more expensive grip truck from a lighting and grip rental company in order to tow them. Lighting rental companies will not send out a grip truck without a company driver - further adding to the expense of renting a movie generator (in this market driver rates run about $500/10hrs with overtime after 10hr).
One of only a few LEDs available with PFC circuitry (and the only Fresnel with it), the L7 Fresnels will create virtually no power waveform distortion when operating on portable gas generators. For this reason, the generator will be capable of operating larger, or more smaller, lights than it could otherwise. With PFC in all your heads, you can load an inverter generator to capacity (use this link for details.) Which, in the case of our modified Honda EU6500is means the ability to operate up to 30 Arri L7s – effectively eliminating the need for a diesel generator in some situations. Even when you require a bigger gun like a 4k Par, the low line noise and power consumption of the Arri L7s make it feasible to operate an entire location package from a single Honda EU6500is. For instance, you can operate up to 10 L7s in addition to a 4k Par on the enhanced 7500W power output of our Honda EU6500is. And, since, Arri plans to introduce the ARRIMAX reflector technology to the 4k HMI power class (resulting in a head with the output and light quality of a 12kw Fresnel that can operate on a portable Honda generator), what can be accomplished with a portable gas generator will be tremendous when used with camera systems like their Alexa (that is capable of a fourteen stop exposure range and ASA sensitivities of 1600 without grain.)
With Power Factor Corrected L7 LED Fresnels, ARRIMAX reflector HMIs, and Kino Flo Parabeams, you won’t need anything more than can be operated on the enhanced 7500W output of a Honda EU6500is to get decent production values in most production situations – effectively eliminating the need for a large diesel tow generator, with all its hidden costs. This is what has Harry Box so pumped about our HD Plug & Play Gen-set and why he has included it in the 4th Edition of his “Set Lighting Technician’s Handbook” ( use this link for details.) When you start to use the new math of not only lower power consumption, but also of lower line noise, to calculate what can be operated on a portable gas generator, you quickly realize that the savings of not having to rent a large diesel tow generator to get good productions values starts to outweigh the additional cost of the Arri L7s. And, when you factor in the hidden costs of renting a large diesel tow generator – the rental house grip truck, truck driver to tow it, and the extra electrical crew to distribute the power – the cost savings more than offsets the additional cost of the L7 LED Fresnel.
The final thing Arri did that makes me feel comfortable investing in them, was to build the L7 on an expansible platform. Not only, do the heads allow for the incorporation of more efficient LED chips when they become available, but the light engine is also fully upgradeable, ensuring that the fixtures can take advantage of technology advances as they happen.
 They are also compatible with planned future optic accessories that will expand the L-Series versatility. Able to incorporate future developments in LED technology, the expansible platform of the L7s ensures that they will have a long useable life and so will assure a return on investment in them. Given the rapid pace of LED chip development, I can’t think of another LED fixture that won’t be obsolete in a year or two, making the Arri L7 Fresnels the safest investment out there.
- Guy Holt, Gaffer, ScreenLight & Grip, Lighting and Grip Rental and Sales in Boston.
Holy cow batman.
This is an amazing thread. Thank you so very much for this information.
I think you are right on every point ... its the resulting value proposition I'm arguing.
I am definitely attracted to the color mixing feature. Especially if I work on Star Trek again - finding gel combinations on that show is always exciting, and usually what I want is inevitably a four hour drive from the studio.
The IP54 weather rating is interesting. I tend not to shoot in the rain - but knowing this unit can handle a little water is worthwhile.
Here is my economic dilemma:
Right now I can get the same service from a 650w Arri Tungsten fresnel, and a CoolLights CFM-150 CDM fresnel with gels.
650w tungsten fixtures (my unit of choice for basic interior hardlight) and 150w CDM fixtures from CoolLights.
They are much more cumbersome, and certainly present more practical difficulties in use. Even so, replacing those two fixtures and the gel I'd use with this single fixture represents no more than $1500 worth of hard costs. Yes two lights are much bulkier, and because I have to select between them, and potentially be without one ... plus finding gels etc etc - there is an ongoing value to the L7-C
Now, it turns out that the Arri L7-C is almost $3000 (I just called Arri) I just can't stretch that far right now.
I still REALLY want to own at least two L7-Cs, but they won't supplant the tungstens and HMI's I need them to serve alongside for some time.
