Hello, I got a problem with a dammed 4K clip.
Im exported a XMl from FCP 7.01 and then with clipfinder to conform to R3D, when Im import the XML file on After effects CS4 works correctly with color correction and other stuff........32bits per color, maximun settings on debayer options.........and then I export in Proress 4444 in 4K resolution.
The clip rendered on CS4 are too huge, 15 seconds= 1,5 GB ( It´s normal, 4K, 32Bpc :biggrin: ) and the QT have a problem to reproduction with dropped frames.
Its not enough a mac pro octocore with raid0 and 16GB ram ?
Thanks a lot.
Thanks a lot.
