Emyr R. E. Pugh
Our RedRocket is no longer functioning. When I load Redcine-X, footage won't play at normal Rocket speeds and when I run RocketCine-X I get the following messages in the following order one after another:
'Your RedRocket driver is out of date. You have version: 0.0.0.0, you need version 1.1.4.0'
'Your RedRocket driver is out of date. You have version: 0.0.0.0, you need version 1.1.6.8'
'Your RedRocket is in a 0x PCI-Ex Lane. The RedRocket requires and 8x lane to perform properly.'
'Your RedRocket has detected a PCI-Ex speed of 0. The RedRocket requires a minimum of 250 to perform properly.'
'Your RedRocket has detected a PCI-Ex Lane width of 0. The RedRocket requires a minimum of 64 to perform properly.'
I've tried re-installing the RedRocket Drivers and 1.1.8.6 Firmware from red.com/support, following all directions to the letter, but it's not rectifying the problem.
Any suggestions?
Any suggestions?
