problem with Clipfinder and Red Rushes
Serge Manto
Riga, Latvia
proffy-studio.wix.com
I try to transcode QT file from r3d using Clipfinder, rendering begins, than when in the rendering status bar it noticet than all frames are complete, but rendering digram continue to be active but stops at place less than half distance. In the list window it indicates that render is complete, but in render window render start button stays green, and nothing happens. So when i try to open rendered file it cant be opened.
May be i should to do something else?
At the same time when i try to do the same in Red Rushes it is stops at 30-40% of rendering and render nothing.
Please help!
Thank you.
Is this happening only with a specific clip or with all clips ?
If it happens with one clip but not with others the clip may be corrupt.
Also, check the system log for any Clipfinder-related messages.
If possible, send a screenshot of Clipfinder with the main window and the render window side by side while it is rendering.
Hans
Hans
There is 2 screenshots before start rendering, and when rendering stops.
Yes it happens with all clips, it cant be a corrupted file.
Yes that works with v 2.2, Thanks!
One more question: when i import clips in to Clipfinder there in coloumn "data" it shown by default date 01/01/80, how to do for in these coloumn was automatically shown date when the shot was done? And than when render for to have automatically subdirectories for each shooting day?
Thank You.
