problem rendering at 1896x1024
bainier
hi, i've tried to set the sequence settings in final cut pro to 1896x1024 (1,85 aspect ratio) but for no reason, when i render the sequence a green line appears on the left of the picture, and not even on every shots, I thought it was a little bug inside final cut, but when i export the sequence the green line is still there...
mmm, seem that is a problem with a Prores HQ clip in an 8 bit timeline or export...
