Just tried mounting my Raven on a Movi Pro. Connected to the 12V Aux Power and the camera fans spin up like it's booting, then stop, then start, then stop...
Is this a sign that it's not getting enough voltage?
you have two d-taps on Movi, one is 14-12V and the other one is 12v (the outside one), put it in the 14-12V.
what is happening to you is that the camera starts (fans) then it wants more power and the board in Movipro is cutting out the power for safety reasons on that port, then it happens again,...
