Problem, pls help!
martinuswho
When I watch the preview of the recorded material on CF I see measured "break" of the picture. It's not freeze frame or drop frame. The same problem occurs also when watching the footage on the FCP and Red Cine. Even after rendering the problem still persists in 2K and 4K. Please advise if someone knows where could be the problem!!! Thanks in advance.
And to add something: most recently the problem occurs on fast or slow pans and tilts.
I'm using build 16_v3.2.5 and I tried not only 4K 16x9 but all other possibilities and it's always the same.
I already did all this. I can review it in Quicktime but the problem is still there. It's almost unnoticeable but on pans and tilts it's clearly viewable.
Could you please tell me shooting settings for 4K row?
I'm not sure if I'm explaining the problem properly. It's not really a break of the frame, it's like a delay... For example if i shoot pan and i have flying bird, the flight of the birds was "corrupted / delayed" few times.
is this problem also visible if you try to watch it frame by frame?
try that - to be sure it's not connected directly with computer/processor power. so if you can see it anyhow - it's on the recorded material, not connected with computer performance.
just a thought.
filip
I watched it frame by frame and there is no problem. The problem is on the recorded material and even if I'm not shooting i see the same problem through the LCD (not connected on the computer)
