Pro Res Export height problem 1920x1080
Hello Im working with several resolutions 2k 3k and 4k. Im exporting some files for FCP via redcine-x pro and keep getting a small matte on bottom and top of frame. is there a quick solution through export to rid of these or is it a scaling issue.? I'm new ith the red and have a project working with 7d footage and need it to match. any help or suggestions will help thank you!
If you are matching to 7D resolution, that would be 16x9 aspect ratio. Some resolutions require cropping. Otherwise you will get letterboxing. You need to select Fit Height under Framing Control for each clip before exporting.
