Paul Kalbach
- Apr 21, 2007
- Oakland, CA
- www.artichokepro.com
I see that the time code cable for Red One has the same connector as the TC port on Pro I/O. Can I use it; will it work? Likewise, the Viewfactor Origo Start/Stop Switch which worked with the Red One Aux/GPI port has same connector and pin-outs as GPIO port on Pro I/O. I assume the Origo will work with the GPIO on Pro I/O as well, yes, no? Just want to double check in case there's something I'm overlooking...
