OOBO = WHEN OUT OF BACK ORDER
Current: Pro Battery Module (Dual) is $1250. OOBO 1: $1450
D'oh...
Does this module allow one to replace a used battery with a fresh one without having to shut down as long as one battery is in the module..? Thanks
There's a power tap on the +1 module, which you'd need to connect the battery module anyway (you can use just the dummy "module adapter" instead, but then it's not making functional use of the space).no P tap?
