Koray Birand
- Oct 12, 2011
- London / Istanbul
- www.koraybirand.co.uk
Hi Everyone,
I have been having the following problem for a while. When you do your edit with Premiere Pro and then export as Final Cut Pro XML. If you import this xml file into RedCine-X Pro, you get an empty timeline whereas
if you import the same xml to RedCine-X then you get what you are supposed to get. So I save the project in RedCine-X and re-open the same project file in RedCine-X Pro then it works but I hate to use RedCine-X as a bridge. Anyone experienced the same problem ? Any solutions ?
Thanks.
Thanks.
