Samir Patel
Premiere Pro is killing me with this master clip effects control setting. I tend to shoot often with the Canon 24-70v2 in changing conditions and find that at full wide I am about a 1/3 to 1/2 stop brighter than at closeup. So on top of that when I move from daylight to under a tungsten light for a second it also screws me. Dealing with the 1 master clip setting on top of using IPP2 is a pain in the ass. Is there a way to set the master iso once when I originally import the clip. Then flip a switch somewhere in the menus to make every cut I make within a file retain specific raw iso adjustments to those specific cuts? (which I would alter as the second step) Or do I just need to abandon Premiere and go to Resolve or something else for this case?
