Ingo Schmoll
- Dec 14, 2013
Hi, I'm experiencing a problem with RED footage when applying an effect in Lumetri. The easiest way to recreate this is to apply a vignette onto the Red footage. In the preview window everything looks fine when playing it back. But if I export the footage to any kind of codec (ProRes, MXF, h.264 etc.) the effect on the file that is exported will flicker. Other effects applied by Lumetri will also show a slight flicker, not as bad as a vignette, but still quite visible. Im only seeing this problem with RED footage in any resolution.
-OPEN CL on my 15" MacBook Pro 2016 with Touch bar with Radeon 460GPU and on my late 2013 MacBook Pro 15"with Nvidia GPU will have the issue
-Software render works fine
-CUDA on my late 2013 MacBook Pro 15"with Nvidia GPU also outputs without the issue, but I dont really use CUDA since it has other huge compatibility issues with Premiere
Heres an example:
https://vimeo.com/206706238
So I am wondering if you guys experience the same?
BTW Im using the latest version of Premiere Pro 2017.0.2 on the latest version of OS X Sierra 10.12.3.
Heres an example:
