POSTED: Release Build 30 (30.6.0) & Beta Build 31 (v31.6.9)
Status
Not open for further replies.
Brent Carter
REDUSER.NET
Irvine CA
We have moved RED ONE camera firmware Build 30 (v30.6.0) from "beta" to "release" firmware version. All new RED ONE cameras will ship with this firmware version...
Changes from v30.5.0 to v30.6.0:
* Resolved Genlock syncing error following return from on-camera clip PLAYBACK.
* Improved Blue channel image quality for RED ONE cameras with Mysterium sensor.
* Improved Blue and Red channel performance under highly saturated green screen.
* Resolved image capture error with 2K resolution recording at 117 - 120 fps.
* Addition of MEDIA MODEL and MEDIA SERIAL number to VIEW STATUS menu.
* Correction of VIEW status in UI when VIEW switched by GPI or User Key.
* Correction of FOCUS false color error when operating in VIEW = RAW.
* Correction of LOG file write confirmation error when no media is attached.
* Preliminary support for Bomb-EVF viewfinder.
* Support for FIXED and SYNC monitor modes with Bomb-EVF
* Support for User Key 3 and 4 functions from Bomb-EVF.
* Support for TALENT tally with Bomb-EVF.
* Support for OPEN GATE mode with Bomb-EVF.
We have also posted the latest BETA version of RED ONE firmware on www.red.com/support - Build 31 RED ONE Beta Firmware, v31.6.9 (password-protected).
Changes since last release (v30.6.0):
* Increased reliability and capability of Master / Slave operation.
* Support for hot plug of Master / Slave communication USB cable.
* Indication of Master / Slave status in UI.
* Slave camera prevented from initiating a record operation.
* Slave camera clip name forced to use Master camera's I.D.
* Addition of POSITION function to set Master camera as CENTER, LEFT or RIGHT.
* Updated metadata in .R3D file to record Master / Slave and camera Left / Center / Right position status.
* Updated metadata in .R3D file to record User Action and Title area / positions.
* Common media FORMAT, CHANGE and RESET commands across Master and Slave cameras.
* Common media UNMOUNT command across Master and Slave cameras.
* Common PROJECT RESOLUTION, QUALITY and REDCODE command across Master and Slave cameras.
* Common VARISPEED and RAMP commands across Master and Slave cameras.
* Common TIMELAPSE commands across Master and Slave cameras.
* Common MAGNIFY command across Master and Slave cameras.
* Common AUTO WHITE BALANCE calculation command across Master and Slave cameras.
* Common MANUAL WB command following Tungsten or Daylight or Auto WB fictions.
* Common TINT setting across Master and Slave cameras.
* Addition of TRIM sub-menu to COLOR TEMP menu.
* Common GENLOCK enable / disable command across Master and Slave cameras.
* Command JAM SYNC enable / disable command across Master and Slave cameras.
* Common Shutter MODE and SYNCRO commands across Master and Slave cameras.
* Common ISO rating command across Master and Slave cameras.
* Common LOOK commands across Master and Slave cameras (excluding FLUT parameter)
* Common LOOK EXPORT and IMPORT for Master and Slave cameras.
* Common USER KEY 3, 4 and 5 set up and enable / disable command across Master and Slave cameras.
* Common Zebra set up and enable / disable commands across Master and Slave cameras.
* Common Frame guide and User Area setup commands across Master and Slave cameras.
* Common TEST SIGNAL commands across Master and Slave cameras.
* Addition of Auto WB as a selectable GPI trigger option.
* Addition of Auto WB as a selectable GPO tally option.
* Support for INTENSITY parameter with Bomb-EVF.
* Transfer of DARK DETAIL parameter to EVF-MENU, and INTENSITY parameter to VIEWFINDER menu.
ALWAYS READ ALL INSTRUCTIONS CONTAINED IN THE DOWNLOADED INSTALLATION FILES BEFORE PROCEEDING.
WARNING: AS THIS IS A BETA BUILD, THIS FIRMWARE IS RECOMMENDED FOR PREVIEW AND TESTING PURPOSES ONLY. IT IS NOT RECOMMENDED FOR USE ON COMMERCIAL PRODUCTIONS.
NOTE: After upgrading firmware, a BLACK SHADING calibration should be performed. Detailed instructions are contained in the Operations Guide ( http://www.red.com/support/release_history/12 ).
If you have any questions or feedback, please contact RED Technical Support at www.red.com/support.
Thanks, BC
Status
