Radoslav Karapetkov
The camera could be modified to allow the rental house to enter a password to set a timer in the camera to shut the camera down after the rental time is up, plus maybe a day or two. The camera could display the time left on the rental to tell the renter when the camera is due back.
The accessories could get a code through their power from the camera that would be required or they would power down, so they would not work on camera's SN not programed into their firmware. The camera password could be used to add more SN to the accessories, that way if any accessories are taken they will not work on another camera since only the owner can change permissions.
The owner would set the timer/limiter so it would also lock out the reset on the clock, and limit the number of turn-ons before the camera locks up with just a prompt for the password.
You could add some combination of buttons to be pressed in some defined order along with the password so that it would be very hard to crack and get the camera to ever work.
You could have the camera burn out a fuse (or worse) or something if someone trys to crack the password more than three times. (it could start beeping continuously until the battery is unplugged also!)
The display can say "This camera stolen from: Don Doe, 123 Main, Anytown, USA" all the time after the rental time has lapsed.
Do not have a way the renter can extend the time, even over modem or beep code through the microphone input, since that would allow a crack.
That would make the camera useless to anyone who steels it, and RED (tm) could tell everyone so to discourage such acts.
I also second this.
Password protection is very important and should definitely be added to future builds.
And it should also be programmable, which means that:
- If you want, you can disable it entirely, which is not recommended, unless you're giving it to someone you TOTALLY trust or if you're operating the camera yourself.
- Set the camera to ask for password on every boot. This could be annoying, but you should also be able to...
- Set the camera to ask for password once every 24 hours - for every shooting day - you log on in the morning and it doesn't bother you again till next morning. Or something similar.
I would also suggest two passwords:
- One for the camera technician [programmable] - Only you and the tech. guy knows that one. I would always send someone I trust to take care of the camera or go on the shoot myself. I wouldn't send my baby all alone somewhere without the tender care of her lover or of a good friend of his
- Another [internal] password that only you should know [programmable and for-your-eyes-only] - in case the technician gets cheated somehow or he turns to the Dark Side or whatever. This password should appear more rarely - once a month or something like that.
Both passwords should be 8-10 symbols at least, or, you know - strong enough.
Also if the camera body is opened, the internal password should immediately activate itself. In case someone wants to try and hack into the system clock or whatever.
All the passwords should be recoverable by the RED Service, of course. In case you forget it or mess something else up.
I guess the RED Team already knows these things and are cooking something up.
Just wanted to give some suggestions.
Merry Christmas to the RED nation!
