PL Revolva Mount on DSMC 1?
Bristol
www.kieranodonovan.com
Does anyone know whether or not it is possible to use the Revolva PL Mount on an Epic Dragon DSMC 1? I know the Kippertie website says it was designed for DSMC 2 but I believe the shape of the mount is the same between the DSMC 1 and DSMC 2? Are the contacts the same for communication between the lens and camera body?
Any thoughts would be appreciated.
It won't work. It's more than a mount issue. I believe the lens port / internal sensor area where the Revolva protrudes back into is a slightly different shape on DSCM1, so it literally won't fit.
Does anyone know whether or not it is possible to use the Revolva PL Mount on an Epic Dragon DSMC 1? If you need some instant cash contact https://directloantransfer.com/instant-cash/ I know the Kippertie website says it was designed for DSMC 2 but I believe the shape of the mount is the same between the DSMC 1 and DSMC 2? Are the contacts the same for communication between the lens and camera body?
Yes, as Nick Morrison already mentioned it won't fit because its only works with DSMC2 equipment
