[SOLD] PHANTOM HD GOLD HD 2K SLOW MOTION CAMERA PL AND NIKON MOUNT FULL Kit - FAST SALE
Status
Not open for further replies.
Azabu Nino
Tokyo
I AM SELLING THIS Phantom HD Gold camera for superb slow motion imagery.
Films in 2K at 1000 fps.
I USED IT ONLY A FEW TIMES, VERY GOOD CONDITION.
IT COMES WITH:
PL MOUNT
NIKON MOUNT
AC ADAPTER
ALL CABLES
BASE PLATE SUPPORT
HARD CASE
SELLING FOR euro 5,500 + shipping
VERY CHEAP PRICE, FAST SALE
FULL SPEC HERE:
https://www.pannyhire.co.uk/product/phantom-hd-gold/
The Phantom HD Gold can capture 1,052 frames per second in 1920 x 1080 high definition. Its capable of giving videographers a gorgeous 35mm depth-of-field
to spotlight exactly where the action is, and supports a maximum low light sensitivity of ISO 600.
Combining the visual quality of high-definition imaging with the high frame rates of specialty cameras. Select any frame rate from 1 to 1,000 fps in increments
of one frame-per-second at HD resolution. With the Phantom cameras shutter, variable to 1/500,000 second, and radically adjustable frame rates, you have seamless control of the duration,
speed and time of a story element.
Depending on the nature of your shoot, employ a raw-data or video work-flow direct from the camera. The Phantom CineMag is the perfect compliment,
allowing you to maximize your recording time, or quickly secure high-speed shots without worrying about download time, and without compromising image quality.
With 35mm depth-of-field and PL lens mount you do not need to compromise the composition of a scene or your story-telling with the HD Gold.
Supports up to 2K resolution
At 2K resolution the HD Gold offers super-35mm field of view and depth of field. Many industry standard resolutions are available including a 2:1 Anamorphic mode.
Record up to 1,000 fps at 2K
Up to 1000 frames-per-second (fps) at 1920 x 1080 or 1500 fps at 1280 x 720. Even higher frame rates at decreased resolution
HD (1920 x 1080), 2K (2048 x 1536) & 2048 x 2048 resolutions
Adjust frame rate in 1 fps increments
Shutter speeds as fast as two microseconds (shutter angle from 1-360 degree)
14-bit sensor depth (42-bit color), active-pixel CMOS sensor
35mm depth-of-field 11 stop tonal range
Hot-swappable Phantom CineMag® compatible
On-camera control buttons for complete control
Circular buffer to internal RAM, or run/stop recording to CineMag
PRICE DOWN
EURO 5,500
Status
