Azabu Nino
PHANTOM FLEX V641 Vision Research - same spec of FLEX 2.5K
MEMORY IS 32GB, LATEST FIRMWARE UPGRADED.
SUPER 35mm CMOS
RECORDS AT 2560 x 1600 pixel AT MAX 1,450fps
RECORDS AT 1920 x 1080 pixel AT MAX 2,560fps
RECORDS AT 1280 x 720 pixel AT MAX 5,350fps
RECORDS TILL 219,200fps on lower resolution.
YOU CAN RECORD THE RAW SIGNAL ON EXTERNAL RECORDER BY THE 2 x HD-SDI OUTPUT 4:4:4
NIKON MOUNT, POSSIBLE CHANGE IT TO CANON OR PL MOUNT.
USED ONKY FOR 1 PROJECT, VERY FEW HOURS, LIKE NEW.
IT COMES WITH POWER ADAPTER AND HARD CASE.
FULL SPEC HERE:
https://ipaimpress.com/phantom-v641-digital-high-speed-cameras/
14,000$ usd
3 SETS AVAILABLE
SUPER 35mm CMOS
FULL SPEC HERE:
14,000$ usd
3 SETS AVAILABLE
