Mohammed El Sharqawy
That's a good question. I have no idea what is they codec that Adobe uses for this, if it even has a name.
Native means native.. when you are working on R3Ds the are read from the native files to the engine which renders you a preview image on the fly while you work..
when you need to render previews.. the preview files are rendered in MPEG2-I frame.. which is a lossy format.. but this is just for preview..
then when you export your final work, premiere reads back from the original files and renders the highest possible quality output the never went through any intermediate codec..
the codecs that is discussed here are used to be the intermediates if needed.. say, you need to add some stuff on the video the needs to be rendered from an external application.. then you need an intermediate codec..
FCP is a strict quicktime application, it simply can't read the native files if they are not converted (on the fly or pre-converted as proxies) through quicktime.. that why apple invested in a good intermediate codec.. just lack of technology.. on the other side adobe invests development on reading the native original files as they are with highest quality direct processing, the use of gpu power and benefiting from 64-bit architicture you get realtime playback..
