[SOLD] Panasonic BT-LH2600WP W/Hard Case and Panavision Handle - $500
Status
Not open for further replies.
This has been a great Monitor with hard case. We used this as a Production Monitor so everyone on set could watch but not be near the camera. Used by makeup, script people, etc
The monitor was used but still has a great picture the only issue is the small mark in the lower right-hand corner - Please look at photos.
The case is by Mastercases and custom Handle was made by Panavision, This was the same setup that they had for there rental line for when their monitors would go out on rental.
Please ask any questions and if you want to bring your camera to hook up to test it before you decide please let me know.
Come with All the BNC included in the photos I don't know all the lengths but ranges from short to real long cables - I have not tested each cable so I'm not sure how they all work but I did use them to test the monitor to get a picture.
Info from Panasonic web site listed below,
Model Description:
26" HD LCD Monitor, SD/HD-SDI, composite video, YC, component, stereo audio
Model Details
This display's 26" diagonal yields four 13" pictures when used with a quad splitter. It includes a waveform monitor with superimposed function that graphically displays luminance levels from -5 IRE to 108 IRE in any of the monitor's four corners, and a freeze frame function allows frame grabs for image comparison or analysis of the entire frame or its center alone.
Other features include CineGamma™ compensation expressly for use in VariCam FILM-REC monitoring, amplified stereo speakers (two RCA pin jacks input or embedded audio on SD/HD-SDI included), and audio level meters superimposed and see-through for up to eight channels from HD-SDI.
In addition to GPI and RS-232C ports for external control, the monitor's built-in menu can be positioned in five different screen locations. The menu includes control of the built-in fan, preset or manual video control adjustments with indicator lights for non-unity settings, and a three-level tally lamp (red, green or amber). Color temperature is user-adjustable to D9300K, D6500K, or D5600K, and there is a 2.35:1 anamorphic mode for viewing 16:9 cameras with an anamorphic lens adapter.
Product Weight:38.58 lbs with stand, 33.07 lbs without
Dimensions:26.09"W x 17.97"H x 10.63"D with stand
26.09"W x 17.63"H x 4.5"D without
Features:
Features:
• True 16 x 9 aspect ratio
• Resolution (1,366 x 768)
• Audio Level Meter (up to eight channels from HD-SDI)
• Embedded Audio capability built-in
• 80% of 4 x 3 safety marker can now be seen in 16 x 9 mode
• "Pixel to Pixel" mode for 720p or 1080i HD signals for critical focusing
• 26" Diagonal yields (4) 13" pictures when used with a quad splitter (Miranda or Evertz)
• High-speed response (no blurring during panning because of our overdrive circuit)
• Waveform Monitor (a super imposed function that graphically displays luminance level from -5 IRE to 108 IRE in any of the monitor's 4 corners)
• Freeze Frame (entire frame or centre)
• Split Screen (live input versus freeze frame)
• 2 SD/HD-SDI inputs (auto sensor)
• Frame marker lines (4:3, 16:9, 2.35:1)
• Five programmable / user-defined function buttons
• Diagonal line compensation2 smoothes out jagged noise
• Horizontal / Vertical viewing angle (176°)
• Cine Gamma compensation
• Component input on BNC connectors
• Amplified stereo speakers
• One piece design (does not require separate AC power supply)
Specifications:
Panel size: 26"
Aspect ratio: 16:9
Resolution: 1,366 x 768 pixel (WXGA)
Display colors: More than 16,700,000 colours
Viewing angle: 176°
Video input: Video: 1 line, BNC x 2 (through-out connector x 1)
Y/C: 1 line, 4-pin x 2 (through-out x 1)
Analog component (Y, Pb, Pr/RGBS): 1 line, BNC x 8
(through-out connector x 4)
With RGB-COMP input, it is R, G, B, HD, VD, BNC x 5 (through-out cannot be connected)
SDI: 2 line, BNC x 3 (switched-out connector x 1)
Audio input: Pin jack x 2 (stereo)
GPI: D-SUB, 9-pin
RS-232C: D-SUB, 9-pin
Video: EXT SYNC signal level: 0.3Vp-p - 4.0Vp-p
HD/VD signal level: TTL level
Audio: Audio input signal level: 0.5Vrms
Speaker output: 0.5W + 0.5W
Power required: AC 100V - 240V, 50/60Hz
Power consumption: 124W
Dimensions(WxHxD): 26.5" x 18.2" x 10.8" / 663 x 455.2 x 270 mm (including stand)
26.5" x 17.6" x 4.5" / 663 x 451.5 x 114 mm (without stand)
Weight: 17.1 kg / 37.6 lbs (including stand)
14.5 kg / 31.9 lbs (without stand)
Operating temp.: +5°C - +35°C
Operating humidity: 20% - 80% (non dew)
Storage temperature: -20°C - +60°C
Storage humidity: 10% - 90% (non dew)
Status
