Adrian Jebef
- Jun 25, 2010
- Los Angeles, CA
- adrianjebef.com
case in point
:banghead:
Adrian, no matter how much you might want it the ISO is just not a constant value, on any digital camera. Despite what Arri, Canon or Sony might tell you they are all reccomended settings. My experience with the Alexa is consistent with my experience with the Epic in this regard, ISO 800 provides the best starting point but the actual exposue I use is based off the scene's DR and the intent of my lighting. When using a handheld meter or spot meter I'll set it to ISO 800 but I only ever use handheld meters for rough measurements and ratios. The actual iris setting is determined using the in camera histogram or a calibrated monitor.
If we want specs, as in what does the manufacturer say well that would be 66db S/N ratio, 13.5 stops of dynamic range on the Epic. The M-X sensor did not change the sensitivity of the camera per se it changed the noise floor. How RED goes from point A (RAW data) to point B (an RGB image) is not summed up with one number or one answer for that matter. If one really wants to understand the nitty gritty details of how that happens, it takes more than a glance at a spec sheet. It requires testing and experience. Why? Because there are some things that can be measured scientifically and there are some things that are subjective and can only be judged by hands on experience.
Adrian, I want to believe you are only trying to drill down into the nitty gritty details so you have definitive answers to provide to people when they come to you for those answers. I want to believe you just want to make sure you understand exactly how the RED camera systems work, right down to the very last spec. I respect that. I don't see a problem with asking the questions. I will be honest though, there have been a couple of posts where it comes off as having an agenda that goes beyond specs. In may not be intentional but it reads that way. So, hopefully this thread doesn't deteriorate. There's some good info in here, some opposing viewpoints but that's okay, sometimes that can lead to really good things.
Great post Blair, this is excellent practical advice. ThanksOne of my favorite methods for getting the most usable code values into the RAW data set is to adjust the iris while watching the 800ISO RGB histogram. What I'm looking for is how the values stack up or spread out, particularly when I take it too far to either extreme - how does it behave? Early on I learned the hard way that there were times that exposing to the right as dogma made noiseless but flat images that lacked guts no matter how much I jacked them around in post. Bottom line, each scene and lighting condition has a natural distribution of values and in most cases maintaining an accurate representation of those relationships will yield the most useful starting point for grading.
Cheers - #19
BTW, I don't really subscrube to this debate... Hahahaha. But I'll vote 800, just to show my opinion on where it ia usually smartest for most for the most pleasing imageresult under most conditions for most people, unless... of course, you wanna do it differently...
Hahahaha
Debate ??? I'm just after a few beers with friends!
:cheers2:
Matt... that would work really bad. Try the oposite,,,
due to the whiteballancing you need to underexpose the tungsten a bit, while daylight will work better at 320, if you have to,
This thread OTOH...
It IS fun that this is an "opinion" poll, though, and when the chief engineer answers, noone seem to listen...![]()
I have no idea how G N can take this... People do not seems to take any time to read what has been explained again and again to them.
TO RED please pull out (or rename) raw view. It has confused people and you are suffering for it. Raw view makes no real sense and now since the Mx and other advancements is not needed.p
Even my partner is completely confused by Raw view (unlike GN i have explained 3times and that is it). He really will be better off without the option.
Michael L
