on-screen using DRAGONcolor/REDcolor or REDlogfilm
Oron Cohen
Tel Aviv/London
couldn't see an answer for this anywhere, could you use/see Dragon color 1 or 2 or REDlogfilm on screen with the Raven? They say Raven doesn't support 3D LUT, but I'm guessing this is very basic for monitoring the image?
Please if anyone from RED or anyone that tested the camera could share this info.
Yes, Raven will have a RAW toggle. No 3D LUTs. Will be under tools.
When you say that, you mean that I could see all the different colour spaces like REDlogfilm, Dargoncolor2 etc yes?
To be honest, I never used a custom LUT on a RED, the Dragoncolor (or what was before it) + REDlogfilm is more then enough for me to get a sense of how the image is going to look, sometimes I'll ask the DIT to have a custom LUT on his computer so I can view the rushes with it.
Yes of course. It just doesn't support 3D LUTS. Like the current Red Dragons don't.
No. You simply have a toggle between RAW or not. I believe it uses one of their color spaces, not sure which one though.
Why? And why only one color space? We have been told that LUTs are not available on Raven, not LOOK menu settings. I think you should be able to go inside the menu settings > look and modify saturation, contrast, brightness, exp comp, color gain, flut, shadow, sharpness, curves, redcolor/redgamma version (which is what you're asking for), etc. It will only affect monitoring, and looks can be created inside redcinex and foolcontrol. Correct me if I'm wrong because RAVEN user guide isn't out yet.
http://www.red.com/learn/workflow/redcine-x-saving-looks-camera
It works the same as all epics/Scarlets do
