OLED Monitor Failure
Robert Hart
Firstly, off the bat, this is not a RED specific issue but might influence the future care you take of your OLED viewfinders of whatever flavour.
Two P+S Technik OLED electronic viewfinders specific to the SI2K camera system have developed an identical fault within a similar timeframe. The SI2K optical viewfinders came to market well ahead of the RED versions so may involve earlier tech which may have presented issues subsequently resolved in later manufacture.
Both finders had been stored indoors and saw little use over a period of six months. After a subsequent usage on the same project, both displays have developed an "ink-stain" artifact which is penetrating from the image borders. Replacement panels are user-installable but horrendously expensive. Their assemblage is within a proprietory mounting module which is low volume and unique.
I initially thought that I had inadventently "sunned" the display by rear-view mirror light getting in through the eyepiece. However, on the same assignment the viewfinder on the second camera developed the same defect, only recently discovered. I know for sure that eyepiece was not "sunned" as the finder was boxed and built to the camera on the location which was an evening event shoot. Both had been stored on the same premises indoors for about six months through our winter here which is also our rain season.
After doing bit of reading, it transpires that OLED small-screen tech has a known failure mode. The mechanism involves "trace amounts of H2O" which is water plus a thermal process, which I imagine is happening the next time you turn the thing on. A black stain appears at margins and works its way towards the centre until most of the display is obscured. It cannot be reversed.
Whilst RED OLED finders are not identical to the P+S finders which came first, it might be prudent to make sure that all OLED electronic viewfinders are kept well protected from damp. In storage it may be wise to use a lot of new or freshly dehydrated silicagel dessicant in the box which holds the OLED finder to minimise any form of moisture ingress or humidity dewing getting at the organic layer in the OLED panels. If OLED tech ends up being a commercial dead-end, then product support may well die with it.
Attempting to preserve from moisture would seem to be the best bet against the future.
RED finders are not an option for us SI2K diehards. The SI2K finders are fed their signal via SVGA D-Sub connectors.
If anyone has any info on small OLED display panels as available parts, it would be appreciated. I like the OLED side viewfinder but a big and growing half-moon stain kind of tarnishes the experience.
Furthur to my post above, on inspection of the OLED screens, one has been "sunned" as I previously suspected with a signature burn and halo blemish visible. The other has a "black ink" sharply defined defect incursion from an edge.
I think it remains prudent to minimise moisture contamination risk by removing all possibility of ingress, taking the usual precautions against condensation when moving in and out of hot and cold humid environments and using plenty of dessicant cels or sachets for storage containers.
RE: OLED FAILURE
RE: OLED FAILURE
Stefan.
Thank you very much for spotting that error and bringing it to my attention. I shall try the webmasters to see if they can change it.
Thank you webmasters for fixing that error so promptly.
Furthur to the above. So far it looks like eplacing the OLED panel, a small display on a doublesided PCB with processing bits and pieces on it, could be a costly business.
The part is normally associated with military applications.
I have emailed the manufacturer but whether they will want to deal with little old one-person me may be moot. We shall see. One hopes that with the uptake of stereovision goggles and resultent economies of scale, the cost may come down. So far EUR2,000 and US$1,000 are numbers I am running into.
The moral of the story is - look after OLED finders and especially make sure they do not see the light of day though an uncapped dioptre or get damp.
