Bob Gruen
- Jan 17, 2008
- Age
- 54
- Atlanta, Ga
- www.rannugmedia.com
First, even with the bugs, I still really love the Adobe products and their integration.
OK, I keep finding bugs and managing workarounds, but this one is really temperamental.
I'm editing a feature in Premiere that has quite a bit of embedded After Effects comps and some simple Premiere video effects. It was shot and I'm editing in 4K 2:1. All of my sources are set to 'low' (in both AE and Pr) and my editing widow resolution is '1/4' running and 'full' when paused. I'm running on Snow Leopard 64bit with 10GB of ram and a NVIDIA GeForce 8800 GT (non-CUDA, pity that... Hint hint...)
Sometimes when I render effects in a sequence, the rendered sections get squeezed about 15%, and black bars appear above and below the image. It is an all or none occurrence within the sequence. I've had luck with going into the Sequence settings -> playback settings -> aspect ratio conversion to none (which dumps out the render files) and then I'll render out the first effect. If the first one does not squeeze the image then the rest of the sequence will be fine.
I currently think the behavior works like this: If I dump out the render files and render an AE effect first, it goes successfully and the rest of the rendering will be fine. If I render out a Pr effect (like a fade in) it squeezes for that effect and the rest of the sequence's effects will get squeezed. I'm testing that theory now...
Bob
Bob
