Nawaf Alsabhan
- Nov 11, 2012
Hi guys,
My friend is editing a short I shot with the Epic in 5K, I transcoded the footage in Adobe Media Encoder Cs6 to prores 1080p, after he finishes offline editing, we should export XML to redcine-x and reconnect the r3d files to color correct.
I did a test of this and all worked so far, but after I color correct in redcine-x, there are a lot of options from redcine-x, which one should I use?
Export (shallow) to Fcp-x xml: this seems to work easily, but the audio gets deleted when I import the XML to fcpx, is that normal? Also, the clips seems to be 5K in fcpx, but Modify RED RAW Settings is disabled, I'm wondering why, are they a copy of r3d files? or transcoded to prores?
Export : there are a lot of options here, such as R3D Trim, Quicktime, and Quicktime Wrapper, which one should I use?
FYI: I want to send the color corrected r3d files back to fcpx, to add titles and export a h264 1080p.
