George Nathanson
Get two of these... one mounted to the front of the Rptr the other mounted to the top... Viola two side rosettes. Not the the best solution, but better than grabbing cold hard metal (no offense wing "grips")
Digging that rig. Like how the handles are forward of the front of the camera body since there will likely be times the lens is heavier than the body/battery. I'm an EVF guy, but for LCD fans that mounting point is a good place to put the weight/leverage of the screen near typical COG.
Sidebar:
I'd be curious if the pivoting arms could be reoriented to support operating from the behind the camera. A typical hard position build for EFP uses a bomber fluid head, monitor top rear of camera body and control handles/grips/actuators on the pan arms for zoom and focus control. Many live shows will stick with more traditional video cameras for a long list of reasons. That said, as long as you can feed a compliant signal to the live switch, using REDs for multi-cam is still a thing. IMO, there's some real value add if I can avoid having to rent a studio kit for sports/IMAG/events/etc where I need to stand behind the rig.
This note is not just for the OP - who may be all about the handheld and not particularly interested in other configurations - but also for the usual suspects who make this kind of gear. Especially since we now have some slick, compact, wireless FIZ controllers that can be mounted to most handles.
Cheers - #19
This extension was borrowed from a shoulder rig
