[SOLD] O'Connor Model 30 Fluid Head with Peter-Lisand Wood Tripod
Status
Not open for further replies.
David Hessel
Includes:
O'CONNOR MODEL 30 FLUID HEAD (COSTA MESA, CA)
PETER LISAND WOODEN TRIPOD - MODEL NO. O'C-CBT (EDGEWATER, NJ)
Tested and working. Head moves smoothly in all directions. Adjustment knobs work as they should. Condition is good with cosmetic damage consistent with is age.
Please feel free to ask questions or request more detailed photographs and information.
$220
O'CONNOR MODEL 30 SPECIFICATIONS
Capacity ........... 30 lbs. (13.6Kg)
Weight ................. 5 lbs. (2Kg)
Size ........ 4-1/4" high, 7" wide, 5" long
Pan ........................... 360°
Pan lock ...... Independent from fluid system
Tilt............. 60° up and 60° down
Tilt lock Independent from fluid system
Counterbalance ... Adjustable in field from 10 lb. to 30 lb. camera
Camera mounting screw .... 3/8-16
Base ..... Flat (3/8"-16 threaded insert)
Handle .... Vertically and horizontally adjustable
Temperature range ..... 0 -20° to 120°F (-29° to 49°C)
Material ............. Cast aluminum
Finish ... Black wrinkle baked enamel, anodized or plated
Bearings ..................... Roller
Shipping weight........ 7 lbs. (3.2 Kg)
Status
