[FS: SUPPORT] OConnor CFF-1 Follow focus with hard case
Matt Gottshalk
Potomac Falls, VA
www.mcgeedigitalmedia.com
Great condition. Very solid.
Has normal wear marks from using it.
Comes with yellow storm case with custom laser cut hard foam.
Main Bridge
Swing Arm
Handwheel for CFF-1 Follow Focus
Studio Rod Bridge
Driver Gear (43 Teeth, 0.8M, 6mm Face, Cine)
Driver Gear (35 Teeth, 0.8M, 10mm Face, Cine)
Driver Gear (50 Teeth, 0.6M, 7.5mm Face, Fujinon ENG Focus)
Driver Gear (60 Teeth, 0.5M, 7.5mm Face, Canon ENG Focus)
Marking Disks (Set of 10)
The CFF-1's modular bridge snaps onto either 15mm or 19mm rod systems, eliminating the need for separate bridge plates. The unit is also compatible with existing follow focus accessories such as whips, gears, and cranks. Its low clearance makes it ideal for today's large diameter lenses, as well as those in the future.
FEATURES:
-Multifunctional, modular design: single bridge accommodates both 15mm & 19mm studio rod systems
-Compatible with existing professional follow focus accessories
-Low-profile design is ideal for large barrel diameter lenses and for future optics
-Swing Arm can be mounted on either side of bridge for maximum versatility
-Minimal Backlash Mechanism guarantees an exacting focus pull with less play and higher accuracy
-Constructed of lightweight, durable black anodized aluminum
-Eccentric handwheel can be repositioned to optimize visibility
kS8k-2WeOHOjskoOWgndk0rc29sXWzGHgb3buWbuNbA=w1100-h733-no
$3250 shipped CONUS.
Payment by paypal gift, otherwise add 3.5%
