No Aux Input on Audio-Helium Issue
Kenny Mosher
I am having an issue on set where I do not see a Cam Aux input option in the menu, only None or Camera Internal. I need to be able to send sync sound thru the WC A-Box but cannot select AUX input.
If rear analog is not selectable it means your camera doesn't recognizes the i/o module.
Try removing the module check if the contacts are clean and try again.
