[FS: RED Cameras] Nauticam Dive Housing + Red Epic Dragon Kit AUD $15500 USD $10000
Mark Tipple
South Australia
www.marktipple.com
Red Epic Dragon dive underwater housing kit, used for the past few years on shark week and natural history documentaries. Dragon sensor with LLO OLPF is a dream, amazing both underwater and above, my favorite of the Red sensors to date.
Solid as a rock, wouldn't hesitate to use tomorrow on a feature, used last month on a tourism TVC, no issues at all. Ready to shoot kit, add a V-Lock battery and you're set to jump into the water and start shooting 6k Red Raw footage at 75p, or 4k 120p.
Located in Adelaide, South Australia (zip 5169). Worldwide postage available at cost to buyer. Can Facetime or Zoom to see the kit in real time, or email mark@marktipple.com.
AUD $15500 or USD $10000
Kit includes -
- Red Epic Dragon 6k Brain, approx 775 hours : 3 x 128GB RedMags (I'll send 4, but one showed an error last time I used it), 5” Red Touch Monitor, 2 x monitor cables, Wooden Camera V-Lock plate AC Power, RedMag card reader with dongles from FW800 to USBC, Low Light OLPF installed, Side Handle, Red Top Plate, SmallRig top handle
- Nauticam DCES Underwater Dive Housing for Red Epic : Depth rated to 80 meters Includes : Vacuum Pump, Sleds, Tripod Plate, Front Cap, Pelican Case 1610.
Camera installed with side handle attached providing full control of camera while inside housing. 5" screen in the rear. Focus and zoom rings on the left hand so can do both at the same time.
- Nauticam Monitor Housing for SmallHD 502 Bright SDI : Includes : Nauticam NA-502B-S Housing for SmallHD 502 Bright SmallHD 502B Monitor + 2 x Canon LPE6 batteries, Canon LPE6 charger and Australian cable, M16 SDI Bulkhead 25058, ball and clamp for mounting
- Nauticam N120 180mm Optical Glass Wide Angle Port 18809 : New glass installed and used once, no scratches or dings. Nauticam Cinema System Gear Set for Tokina AT-X 11-20mm, both focus and zoom rings. Nauticam N120 60mm extension ring with lock 21160
- Tokina EF-S 11-20mm f/2.8 lens : only used in the housing, sharp and clean as new.
More photos here : https://www.dropbox.com/scl/fo/5wspour36xi9p0rf31cf3/h?rlkey=qdtsavzs630ay0cujpulna38j&dl=0
Most of my reel was shot on this kit : https://vimeo.com/776547539
