My Hobby
A Gyro on that bike rig could be pretty amazing. The body rig is very cool, too.
Are there any shots available from the rigs?
David
Hello
The last week I built a focus ring for my Canon DSLR, which I would like to show here. The problem with this Standartkit that the front lens moves forward or back is if you zoom or adjust the sharpness.For this reason one can not use a standard FollowFocus.So I made me a focus ring, which is wider.
The material is acrylic, and the teeth were milled on the milling machine and turned out on the lathe.
I hope you like it my work.Greetings from Vienna
Super
Really cool, the bike rig is smoother than I would have thought although it does start to oscillate in some segments when shooting from behind. Some form of damping mechanism where it attaches to the bike frame might help, tire pressure and stiffness of bike frame obviously are also important considerations.
Yes, the shots from behind were not good because the bike skidded.
Only after we had the rear tire fills in more air, the images were also just as good as from the front.
Hello
Finally, I want to show you something that I have built for a colleague and his EB camera. There is a mount for his Alphatron viewfinder to fit this on his camera to.
The mount fits on all Sony and Panasonic cameras and identical Kameras. More images are available here:
http://www.plexxart.at/mybb1.4.11/showthread.php?tid=80
Nice stuff Walter!!
I am in Rome Italy, and wanted to ask you if you have any Focus Rings for the Canon lenses such s the 24mm f/1.4L II and 100mm f/2.8L IS Macro I can test, and if they work well I'll buy them off of you.
Is there a possibility to make them Black?
Also can you make the legs for the Slider Black that I can buy alone for my Slider?
Thanks and keep up the good work!
Thanks for the compliment Ketch, to your first question.
I do not have gears for your specified optics, but I can make you which finished in black kunstoff (Pom). This you would have to send me the optics but to Austria.
I recently made ​​these gears for a follow focus for ENG cameras.
To your second question:
Such legs I could do, however, is the production quite time consuming and therefore money intensive. And I would need to adjust the slider as well with me in Vienna to mount the legs.
When you are still interested, please send me a PM.
Greetings
Hello
Today I have for the cameraman and producer colleagues peter Roehsler, which is also reported in this forum made a couple of gear rims for his Primes
Even brief details of the production, the material is a 10 mm thick plate material Pom.
The outer diameter of the gears is 89.6 mm, and each sprocket has 110 teeth in module 0.8.
And so look out of the gears, they were fixed with M3 screws.
And a few pictures of the production:
Close-up:
When you want some gearings for your own, please contact me here
Greetings
Walter
Hello
Long time no see :seeya:
My last Inovation was to make a Cameraman Survival Kit. :001_rolleyes:
attachment.php
In the Picture you see the important 1/4 and 3/8 Zoll Screws for mounting the camera, which are made by myself.
The platelet was cutted by a laser and galvanized.
You find me also on Facebook
Greetings
Hello
Now its the last Version on the Market
attachment.php
I hope you like it. The Set at the left is sold out, the Set on the right side is still aviable.
Whenn you interested on it please contact per PM.
Greetings Walter
Hello
The cameraman survival kits are again available. Newly gotten is than the cinematography survival kit with a mechanical view Finder. :blush:
There is even a shop where you can order the parts. The shop is only in German but with with the photos easy to use.
http://www.plexxart.at/CaSuKi-Shop/
attachment.php
Thanks and Greetings from Austria
Walter T.
