Jason Osterday
- Jun 2, 2008
If we order a dumb mount in the new shop will the order still go in? It no longer says "out of stock" but I'd like to make sure. Thanks.
Is this the one that Vincent Laforet is using for his surfer project?
Been in touch with Andy (who is spoiling me with quick replies). My particular problem is most likely due to the adapter I am using. This problem is specific to using non-Canon-mount lenses with an adapter. Meaning: Most people will never experience this problem, for the others it is easily resolvable. I'll keep you posted (new adapters will probably arrive next week or thereafter.)
What's the difference between a "smart mount" and the "pro mount"???
Also, Andy, what on earth do I have to do to get on the mount list???? I've written, begged, emailed. . . perhaps I should try crying????
Stephen
Just ordered my dumb mount and your site calculated shipping as $13.21 for a total of $363.21, but paypal only rang up $350. I couldn't figure out how to get it to charge me the shipping. I created a new payment after that transaction was complete with the shipping amount.
I'm posting this here to see if this is a common problem.
Setting up the F/stop challenged Wicked Circuits Mount
Installation
READ all the directions and look at the photos on the website BEFORE you start to install the mount. After you remove the PL mount you have to loosen the RED BF ring and compress it before you do anything else. Very easy to install once you adjust the RED BF ring as instructed.
My lenses
I have 4 Canon zoom lenses: 10-22mm, 16-35mm II, 24-70 and a 70-200. All are F/2.8 L lenses except the 10-22. The 10-22 and 16-35 are new. All four were "cherry picked" from at lease 3 new lenses. All are sharp wide open, stay sharp when zoomed and focus at infinity on Canon cameras.
The Wicked Circuits Mount
With this mount I'm getting 3 different results when setting the RED BF adjustment system. The 10-22 is about 1.5 inches turned closer towards the body than the 24-70 and the 16-35 and the 70-200 are about an inch from the 24-70. * Note - I'm talking about turning the RED BF ring not the BF distance being a inch different. The actual amount of difference to the lens-to-sensor distance is very small from lens-to-lens.
So in the end I have 3 different BF settings to get my lenses to stay in focus when zoomed. I think you may find the same result with yours -- one setting does not seem possible for all zoom lenses. If using primes you can probably set it once with your widest lens and go shoot, especially since most Canon lenses focus past infinity.
What I think is going on... This does not make sense...
OK, if on a Canon 1Ds MKII the lenses are sharp, and stay in focus when zoomed then what is going on with the RED? I think it's the IR filter being out in front of the sensor. That distance / air creates a very slight variance from lens to lens in how the light rays travel to the sensor. On the DSLR's the IR filter is sandwiched with the sensor. I'm hoping that on the Scarlet and Epic the filter will be sandwiched like on still cameras. Anybody have a thought on this?
_
I have some reasonable quality Canon still lenses including the 24-70L, and none of them hold focus exactly during zoom on my Canon DSLR, for what that's worth.
You are seeing one of the many differences between still and cine lenses.
You guys are not getting my point.
Yes, I can get all of them to work at one BF setting but then they do not stay in focus when I zoom. And I do not want to have my lenses adjusted for the RED as I use them on both cameras. And I would prefer to not have to reset the BF when changing lenses. To me that is the main point of using the EF's - one set of lenses for both cameras - well at least until I can get my hands on an Epic FF35...
The BIG point I'm trying to make is that the distance between the IR filter and the sensor could be an issue in this process and perhaps that should be looked at for the Epic and Scarlet. Maybe I'm crazy...
When you check them on the R1 you also should use the punch in 1:1 feature that is now available
Jacek Zakowicz, OptiTek
