Christoffer Glans
So Avid is changing the codec naming from the usual DNxHD 36, 120, 185 and 185x (25p) to DNxHD LB, SQ, HQ and HQx.
The problem is that the new naming isn't on par with the quality of the old version of the codec.
DNxHD 36 is supposed to be the go to codec for editorial that looks good enough for reviewing edits and client approvals. The corresponding codec should be DNxHD LB but it's no where close to the quality of DNxHD 36. I'm very surprised that something that's supposed to look the same looks this awful. There's blocky compression all over the image and it's just bad in all ways possible. The only way is to step up to DNxHD SQ, but that codec is way heavier to work from on a laptop with a regular USB3.0 drive (which most client works are done from) while taking up unnecessary space on both the Red Minimag cards and drives for editiorial.
Seriously, how can Avid fuck this up this badly? Aren't the quality of LB supposed to match the old DNxHD 36 quality?
Or is this something Red need to fix with a firmware? Just transcode a R3D clip to DNxHD 36 in redcine-x and then compare that to the MXF proxy recorded in-camera.
