Rob@TheClub
New member
Folks,
I am trying to set up my FCP to edit the proxies of some Red-shot footage. Following the PDF document that BrandonK posted I have dragged the proxies into FCP (obviously having installed the RED QT codec first!) and sure enough FCP appears to recognise them. When I drag them into a sequence and choose to adjust the sequence settings to the same as the clips the sequence adopts Apple ProRes 422 (HQ) as the compressor, not REDCODE. Is that how things should be? I need to render these clips before I can work with them - which is better than processing them all through REDCine but still an annoyance. Also, when I have rendered them my monitor output is only displaying in the top left corner of the screen whereas the frame was previously full i.e. when I browse through the unrendered timeline the stills displayed on the monitor are full screen.
Can anyone shed any light on i) whether I am getting the expected behaviour from my codecs, and ii) how I can persuade the system to play out to monitor properly?
Cheers
Cheers
