Thomas Billingsley
- Apr 4, 2013
I've had this set of legs for the past few years, and loved using them. They are light, easy to set up, tough, and require little maintenance. I have moved up to a larger capacity tripod recently, but would otherwise continue using these legs happily. This purchase includes the ground level spreader as well as the legs. I do not have a case available.
There are minor scuffs and some wear marks on the legs, but they are in great mechanical shape.
Manfrotto says: "The 525MVB lightweight 2-stage professional video tripod is constructed of lightweight aluminum alloy and high-strength plastic composite materials which yield a 30% weight savings over conventional designs. This three-section tripod has two stages with fast-action locks and a convenient 75mm receiver for rapid setup and leveling. Used in conjunction with the included ground-level spreader, delicate floor surfaces are protected from the spiked feet, which are normally used in soft, unstable footings."
Other details:
Asking price for the Manfrotto legs is $350US. Pay Pal only. I will pay shipping to the US and Canada. Purchaser in other destinations pays shipping fees.
Other details:
- 75mm / 3" bowl base
- Double-extension design
- Maximum height of 61.5"
- Supports up to 33.1 lbs
