patrickortman
- Sep 20, 2007
- Los Angeles/NYC
- www.patrickortman.com
Hi All,
I own the above, and when I upgraded my nMP to El Capitan from Yosemite, all of a sudden, the LG display stopped working "correctly" with it.
That is, it no longer sees a signal when using either the supplied minidisplay-to-displayport cable, or a certified VESA-compliant similar cable (that was the first thing I tried). It DOES work with HDMI still... at a miserable 30Hz- not ok!
And the display works fine with my 2016 MBP using the same minidisplay port to displayport cables. No problem at all.
So I don't THINK it's the display.
Does anyone have any idea what's up? Yes, I tried making sure the "enable displayport 1.2" was ticked in the monitor's settings. And I've zapped the nMP's PRAM/nRAM and unplugged the power cable for a minute, to reset the system battery whatever thingie.
The nMP is still outputting a signal on minidisplay port, because I am using it right now to drive my HP dreamcolor 1080p monitor (sad).
Thanks for any help!
Patrick
Patrick
