Osman F Arslan
- Feb 25, 2016
- NYC / Montreal
- osmanfiderarslan.com
It is like new. I purchased it never used it. Just tested it a couple of times. It has been sitting in my closet. It comes with everything you see in the photos. Scrims, barn door, Matthew baby pin, studio clamp, bulb. $525 Includes shipping and fees.
The ARRI T1 Location Fresnel is an updated version of the Compact Series of Location Fresnels. Combining research and feedback from around the world and advances in technology, ARRI has designed a series of six Fresnels with over 30 improvements for studio and location lighting. The True Blue Series has a reduced weight, compact size, and maximum light output.
ARRI's cross-cooling system reduces lamp housing temperature by 25% and lens temperature by 17%. With special air channels built into the aluminum extrusion, a constant stream of air passes around the Fresnel lens and into the lamp head regardless of the tilt angle.
When fitted with a 1000-watt bulb (available separately) this fixture will provide a 2.8' (0.9 m) diameter beam of 409 fc from a distance of 20' (6.1 m) at full spot. At full flood (same distance), it will provide a 48 fc, 20.4' (6.2 m) diameter beam.
Stronger, Lighter
Pressure die cast and extruded aluminum components
Many components offer greater strength and resistance to corrosion
Redesigned Stirrup
Stirrup mounting slides and can be adjusted to counterbalance all accessories
Soft contour makes the Fresnel comfortable to carry
The stainless steel friction disc locks securely even when large front-mounted accessories are being used
Easy Maintenance
Routine maintenance and repair are easier with fast, simple access to all internal components
Cleaning is almost effortless with smooth lamp housing surfaces
Safe
Meets IP23 standard and is suitable for indoor or outdoor use providing a degree of protection against falling rain (up to a 60° angle from vertical)
CE rated and independently assessed TUV certification
Laser-cut hexagonal safety mesh lets out more light and is tough enough to withstand location abuse
Stronger, Lighter
Redesigned Stirrup
Easy Maintenance
Safe
