Lens SONY SCL p50 Pl mount does not work in RED ONE?
PepeRed
Hi guys, I am a newbie using the RED ONE mx, I was about to buy a couple of lenses the SONY SCL p50 pl mount, but I saw somewhere that these lenses are not compatible with PL mounts from other brands sometimes, anybody had experienced it??? Thanks
if you can remove the wings/tabs on your PL mount, you can mount the Sony SCL Mki series lenses. if you can't remove them, maybe you can saw or sand them down. it shouldn't deter you from owning the Sony lenses if you want them. there will be a way to make them work.
I found out it will work with out removing anything, Thanks a lot James
