Length of Red Pro Primes?
Michael Frymus
Ontario, Canada
I wanted to know what the length is of the longest Red Pro Prime.
I believe the 300mm is the longest of them all. If it is, then Id need two dimensions.
The length of the longest lens - Not including the 300mm:
The length of the 300mm:
From the very front of the camera mount to the tip of the lens.
Its so I know what length rods I'd need.
Its undetermined if I will be using the 300mm or not.
Hiya Michael. I just measured it for you. It's 22.6cm long
In fact it's not much longer than the 18mm or 35mm
I'm using 18" rods together with a Bright Tangerine Mattebox.
Good luck!
/Andreas
Good luck!
/Andreas
So, is this the size of the 300mm?
What about the size of the longest lens not including the 300mm?
