Scott Selman
These are tough to part with, but since going PL I find myself reaching for them less, and someone can make a great home for this amazing set of glass! This small set has been hand picked by me over the years, buying and selling to get a great set of lenses.
They have all been partially cinevised. 80mm fronts with push on caps and hard EF Leitax mounts. No gears (I just don't use them) but easy to get and install for anyone looking to use these with a follow focus! Iris is not declicked, didn't matter to me either, but again, easy to do if that is what you'd like!
All the glass is very clean, focus is very smooth, great rotation on each lens.
Custom Pelican iM2500 case with laser cut foam, space for a 6th lens, and AKS space.
19mm 2.8 - 273xxxx
24mm 2.8 - 340xxxx
50mm 2.0 - 278xxxx
60mm 2.8 Macro - 327xxxx
90mm 2.0 - 303xxxx
If you know Leica, you'll love the look of this glass!
Here are the images of the lenses - https://www.dropbox.com/sh/af7aj79h4zt89di/AABULFatuLnBITK9RB3pPArUa?dl=0
Happy to talk about this glass and send over image sample from things we've shot - send me a DM!!
$5500
19mm 2.8 - 273xxxx
24mm 2.8 - 340xxxx
50mm 2.0 - 278xxxx
90mm 2.0 - 303xxxx
$5500
