Steve Sherrick
On my iMac 27" I recently started having kernel panics and began the process of checking RAM through Apple diagnostics. Thought I identified a bad module through this process and had OWC replace the "bad" module. The new one they sent seem to flag the Diagnostics as well. So I went through a thorough RAM installation process as this has been known to help when things get quirky like this.
- First I tested each 16GB RAM module. Each one passed diagnostics
- Then I tested each slot with that known good module. Those also passed.
- Then each time I installed a new module, I did an NVRAM reset and a PRAM reset. I would check to make sure the new module showed up in RAM view.
- After all were installed I then ran the Apple Diagnostics again and was presented with the PPM003 memory module error.
OWC has been helpful, but have admitted that they have seen some machines from that late 2015 batch that are quirky with RAM. People send the RAM back and it checks out fine in their test machines.
Wondering if anyone else here has the late 2015 iMac with OWC 64GB RAM upgrade and has run diagnostics to see if it comes up with any issues. Perhaps I got a temperamental iMac.
For anyone with this same config, would love to compare notes.
Here's some other info about my config:
iMac Retina 5K 27" Late 2015
4GH Intel i7
AMD Radeon R9 M395X 4GB
OS 10.11.3
4GH
4GH Intel i7
OS 10.11.3
4GH
