Bob Gundu
- Mar 17, 2011
- Toronto, ON Canada
- www.10fh.com
Yup. And you can mix the battery plates too with Sony.
The cheapo Amazon batteries ($20ish) will power the Komodo but the camera recognizes that you are being cheap, gives you a warning upon startup, and then does not given any battery levels.
Ok, ok, super stupid idea... or is it!?
The Sony NP-F9XX line is the same voltage range and roughly mA sizing as the Canon BP-9XX batts... Why would it be impossible to make an adapter plate for the camera, (or that attaches to the individual batteries) that passes power, and even info and workout a future Komodo firmware update to accept either Canon or Sony battery data thru the info terminals?
Yes, not a small project, but also it seems like the supply of Canon batts is still pretty limited, and Sony NP-F batts have been getting more play in recent years from on-camera monitors and are likely more available.
Just thinking out loud. At minimum, why couldn't we use the Sony NP-F9XX batts even if it's just a direct power adapter?
From the link, it appears that the hybrid part is that is charges both Sony BP-U batteries (as used by FS7, FX9, etc.) and Sony NP-F batteries ("L" batteries). It doesn't seem to charge Canon batteries of any type.
Is there any reason, or any way that I am missing to get Komodo to display voltage of non-genuine batteries, similar to DSMC2/1?
I see no reason why it wouldn't display voltage other than to be annoying. Electrons are electrons. I don't care what my battery communicates or thinks it is doing. I just want to see it say 7.4, 6.9, etc. I know that a 2cell lithium battery is dead at 6.0. Pretty annoying.
Made a power cable in the mean time, but what am I missing?
I think you’re hosed, if you’re solely wanting to power off of BP batteries. The Cube is specc’d at 6-28V input. I think your only real option is to run an adapter plate that has d-taps and/or lemo’s and power with micro/mini bricks. I’ve shot a few times with my friends and he has the CorewSWX plate and runs the micro/mini bricks and it goes forever.
Thanks for replying. I was afraid of that. Unfortunately with v mount t bricks I won't have an option but to shut down the camera to replace the battery and wait the dreaded 30 seconds for it reboot.
