DC Chavez
- Jun 20, 2012
- Redondo Beach, CA
- dcchavez.com
$1,000 for kit
This is a custom package I put together of Kessler Crane timelapse equipment. Here is what Is included in the kit:
Kessler Revolution V2 Head-
The Digital Revolution Head brings the latest in digital motion control technology to a proven Kessler platform that can accommodate rigs up to 20 lbs. Ideal for cranes and jibs as well as able to be tripod or slider mounted, the Digital Revolution Head can be mounted over or under-slung to provide dynamic pan and tilt camera movement in a variety of shooting environments
Kessler Oracle Controller
The ORACLE Control System is the core of our elektraDRIVE line of products. Almost two years in development, we set out to make the ultimate multi-function controller for our line of electronic products. The ORACLE Control System is interchangeable between multiple products, like our REVOLUTION Pan / Tilt System, elektraDRIVE motor pods for the CineSlider & Pocket Dolly, and other products to be released in the future.
Kessler Shuttlepod Mini-
The Kessler Shuttle Pod Mini is a smaller, easier to transport version of the original Shuttle Pod. It is about half the size and half the weight of its big brother, yet still provides the versatility needed to get the manual or motorized shot you require.
The Shuttle Pod Mini is designed to break down into a small, easy to manage package. Using the shorter 2’ rail sections, it can even be stowed in a backpack for those long hikes up the mountain.
Like the larger Shuttle Pod, the Shuttle Pod Mini is totally smooth and silent. It can be used with the track or stand alone on any smooth, flat surface.
Track sections are available in 2’, 3’ and 4’ lengths and can be connected end to end to achieve any length desired. All-Terrain Outrigger feet are available for the Shuttle Pod Mini for track end support. Center supports are also available for use with longer track runs. We recommend supporting the track at least every 4’.
Also includes Pelican 1610 Case with custom cut foam for this kit, outrigger feet, camera control module with Canon trigger cable, motor adapter for Kessler Cineslider and all the necessary cables to make this girl run.
Here is a film I created with a 5D and this system: https://youtu.be/MDr7E3Hid9g
Available for pickup in Los Angeles.
