[FS: GEAR] JVC 21-INCH MULTI-FORMAT LCD MONITOR (LED BACKLIT) - DT-E21L4U B-STOCK AT TMS
JVC 21-INCH MULTI-FORMAT LCD MONITOR (LED BACKLIT) - DT-E21L4U (B-STOCK) - $1595
This is a b-stock with full 1-year warranty. Tested and approved.
PM or call 512-440-1400 for details. Free shipping US only.
The DT-E21L4 is a cost-efficient full HD LCD 21-inch Studio Monitor with LED backlighting, reduced power consumption and improved lifespan.
JVC's new DT-E Series HD monitors to provides a cost-effective alternative to our industry-standard DT-V high-end monitors. They feature a newly-developed TN Panel with LED backlighting that provides improved contrast and black level. With power consumption 20-30% less than conventional CCFL monitors, the DT-E Series monitors are perfect for use as control and studio monitors. The reduced power consumption also makes it possible to add 12VDC support for field use.
[h=3]DT-E21L4U Features:[/h]HD-SDI and HDMI compatible
Full HD Resolution with 1920 x 1080 panel
Composite Video In/Out, Component Video In, Analog RGB Video In, HDMI In, HD/SD-SDI In/Out
3-Way stand for versatile installation
Mercury-free LED Backlight
IMD (In Monitor Display) function based on TSL's UMD protocol ver. 4.0
10bit color processing
16ch embedded audio with level indicator
Do these units have DC in as standard? Or how easy is it to fit?
