Issues since firmware 6.3.17
Brian Mercer
Active member
I have found two issues since upgrading the Raven to 6.3.17. The monitor has a terrible green cast to it. Checked everything in settings and nothing adjusted or changes the green cast. This is only present when viewing live or recoding. If I play back the recoded footage, it looks normal.
The other issue is the HDMI port will not play to an external monitor. This worked fine before firmware update. I have double checked settings, changed settings, changed them back. No signal.
Appreciate any suggestions.
HDMI is now working. Third battery change and it came back.
The green cast appears on live view of both the Red monitor & the SmallHD 502. However the playback footage looks normal.
Update**
Firmware 6.3.27 fixed the green cast issue.
