Jeremy Green
- Jan 7, 2017
Curious if anyone else has run into this issue: I'm running an external audio recorder that I plug an XLR mic into and then a 3.5 line out from there recorder to plug into the DSMC2 V lock I/O. It works about 60-70% of the time. 40% of the time there is a rhythmic static noise (fortunately I doubled up and recorded onto a card via the external recorder). Seems to be random and independent of any settings. We did a shoot with 5 interviews, 3 were fine, 2 had the noise.
The next day we used a wireless lav mic. Worked great for about 2 hours, then I noticed it started making the noise. When I rebooted the camera it was solved.
Obviously I'm a little paranoid now and plan on using a back up recording device for any and all client videos, I wonder if its an issue with the extension unit or the camera?
Oh, one last question, do all RED setups that can record audio have that delay or is the problem solved when you step up to the PRO I/O? Its driving me crazy.
Thanks dudes!
Thanks dudes!
